Kitchenaide dishwasher Motor does not start
unit fills with water, motor does not start.
noting blocking any hose
I see the divirter moving
The motor did engage twice intermittently after replacement
there is power to the motor
replaced divirter motor
replaced motor pump
replaced control board
replaced float switch
diag code is 6-4
  • Replies 7
  • tcolati
  • LearningTech
  • darren412
  • johntech
We cannot help you with out a model number.
sorry.
it is a kitchenaide  kdfe-204ess
1 hour ago, tcolati said:
kdfe-204ess
That number is not working either.
Tried kdTe204ess,  6-4 is float switch.
(most common)
 float switch stuck
bad switch
control misinterpreting the switch
bad wireing between switch and control
(least common)
generally wont fill if float is bad.
error codes can interfere with operation and should be cleared.  Did you clear codes after replacing switch?
are any replacement parts used?
NEXT:
unplug
verify switch operation with meter.
verify good wireing with meter
reset control.
 If issue persist then new control is in order ( may have gotten a bad one, especially if used board)
the float switch shows zero when hooked to a meter (for both depressing/not depressing  the button on the switch) . i would expect to see some resistance,  correct?
When I disconnect the switch entirely, the motor comes on (or course there is no water in it..)
is it possible to bypass/disable the float switch?
From what your saying now if I am understanding you correctly, is that the new float switch you replaced is bad since your getting a zero Reading.  It’s highly unlikely the new float switch is bad but anything is capable !  You have replaced everything but the interface and drain pump it sounds like. I would stop throwing parts at this machine. A lot can happen between your original state of the issue to going through and replacing all these parts.  I couldn’t tell you where to start at this point. Do you have a membership here ??  If not I highly suggest you get one and get some basic trouble shooting techniques  and procedures. It’s really worth your while and is a treasure trove of knowledge for your particular situation. You have gone into a parts changing frenzy here and stuff like that can compound your problem. Good luck and I hope you can nail the issue . Point of information :  if you still have the original control board try putting that back in and see what error codes the old board had stored .  Unless that 6-4 error came from the old board originally and not the new board.  I wish you Good luck either way
Edited by darren412
If you testeed witch correctly like has been said its bad.
search youtube for vidioes on how to perform continuity test.  Once you know your testing it right. Then perform a repair.
 Also like has been said dont replace parts unill you have verified they are bad somehow.
 I would put ALL original parts back in and go from there.
Test for power at components like motors. If no power = not bad
