Manufacturer: LG
Type of Appliance: Washer
Model Number: Wt1101cw
Tech sheet
  • JP WAR
  • Son of Samurai
Try searching the downloads section with a truncated model number and the * wildcard character, like so: Wt1101C*
The manual for your model will pull up there.
@JP WAR - when you search using the truncated model number and wild card like Sam said, be sure you select the FILES section of the site: click into the search box and select FILES. May need to first click "More options" to see "Files". But that's what you want otherwise you'll search the entire site and pull up lots of results you don't need.
