2008 Bosch range model HES 235 C–02 digital display went blank, oven still works
Sabrina Clough
Returned home from a trip to find my Bosch oven display blank and touchpad unresponsive. Powered off at breaker to reset– no change. Inspected the control board to find a burned spot obscuring one corner. Used eraser on ribbon contacts anyway and reassembled... Barely audible "Beep" said it was still alive, so I went thru the finger strokes blindly and started baking using a grill thermometer. Sometimes the touchpad is responsive, sometimes not. I can't get anyone to come out this far to diagnose or repair or accept a carry in and Bosch is no help unless I want to purchase a new, nonrefundable control board and who would do THAT especially since it actually does work, you just can't see what it"s doing via the digital display. Is there any hope of repairing this?
  • LearningTech
  • Sabrina Clough
Burn mark if corner of display is normal part of how its made, likely bad control
 part from repair clinic has a 365 day return policy installed or not
Sabrina Clough
Thank you for the response.
Do you mean that repair clinic sells control boards that can be returned if the new one doesn't fix the issue?
Yes that is what i mean... Your welcome
