Maytag washer A506 hums but doesn't start until...
Good Evening.
I have an old Maytag A506 washer and lately it will not start after filling until I shake the machine of if I have the front cover off, rap the top of the motor with my hand. Then, it works fine.Would this be a motor issue? A Capacitor?
Thank you for your help in advance.
Aaron
  • Motorcity Master
  • Aaron2010
Motorcity Master
If tapping on the motor causes it to start running normal then you've got a bad motor or bad connection in the connector harness. Common on these.  Check the wire plug harness for discolored terminals. I'll pinch them a little and clean them up with terminal cleaner.
Motorcity Master
 This reminds me of my old service van. I used to keep a hockey stick in the passenger seat--when it wouldn't start I had to slide it underneath and tap on the starter motor a few times, then it would start no problem lol. (I wasn't too cheap to get it replaced, I just didn't have time)
