Manufacturer: KitchenAid
Model Number: kscs25qfwh01
Looking for help with this fridge.  Need to check the damper, getting too cold in fresh food section.  Sears says the part number to the tech sheet is LIT2186928 .
  • ApplianceMagic
  • Son of Samurai
If you drop the "LIT" off that number and search the files section with what's left, you'll pull up the tech sheet for your model.
