Manufacturer: Kenmore
Model Number: 79574025411
Unit cooling in FZ section (9 degrees) and ice maker making ice but not much cooling in FF section (58 degrees). This has that linear compressor which another tech changed out a month ago. Pressures are 12 low, 95 high.
Wanting to run some tests but need the manual. Hoping you can find one.
Thanks!!
  • David54
  • Son of Samurai
This one should do it for you:
Thanks!!
