Ice room repair kit
AllStarBob
Manufacturer: Frigidaire
Type of Appliance: Fridge
Model Number: FFHB2740PSCA
 Searching for this unit I find a tech sheet for FFHB2740PS2. First I would like to know if that is close enough to my mo.# or does  it have to be exact.
Second I'm told this unit needs a service kit for the ice room because of frost build up on I/C room coil and nothing shows up. I am having the bulletin e-mailed to me but I won't get access to it till after Christmas and I would like to look it over before that. Thank you
  • Son of Samurai
  • AllStarBob
  • emeraldappliance
If you can get the reference number of the bulletin, we can see if we  already have it uploaded here at Appliantology.
  • 2 years later...
Ice in the fan on this fridge.  Does anyone have the kit number?  Read on here also more parts may be needed?
ffhb2740psba
4a60527298
