Manufacturer: Samsung
Type of Appliance: Refridgerator
Model Number: RF22h9010SR/aa
Customer complaint is the supply line for the ice maker keeps freezing up.  I suspect a bad water valve.  Where is it?  I have looked at the service manuel and i have looked at the fast track.  Neither show the water valve.  I suspect it is in the back of the filter case since some of the fast track photos show a bunch of water lines behind the filter but nothing shows the actual placement of the water valve.
Thoughts, I ideas?
Thanks,  Jeff  AKA ART.
Edited by Art4corners
  • Replies 1
  • Son of Samurai
  • Art4corners
Looks like you already have all the documentation for this model, which is what this forum is for. Your question seems to be about getting technical help, which means it would be best suited for the Appliance Repair Tech forum.
You'll want to verify that you have a valid model number (the one you entered here isn't pulling up anything on Samsung's site), and then post your question as a new topic in the Tech forum. We'll help you out there.
