William Lewis Posted December 28, 2018 Posted December 28, 2018 Manufacturer: Subzero Type of Appliance: Fridge Model Number: 601R/O Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Unit has error code on display ‘EE’ with ‘Service’ and ‘Ice’ that won’t go away. Previous tech had already replaced Main Control Board with no success, I have this call first thing tomorrow and need some testing material for insight for unresolved error code/display issues.
William Lewis Posted December 29, 2018 Author Posted December 29, 2018 Temp Control ranged for fridge was only -5* to 5* like a freezer control, I was able to reslove issue by cutting out resistor 50 on new main board (Per Subzero e-mail) then temp ranges returned to normal 34* to 45* and no more display of error EE, Ice and flashing Service, if anyone has any similar issues in the future.
Team Samurai Samurai Appliance Repair Man Posted December 29, 2018 Team Samurai Posted December 29, 2018 You need the 600-series service manuals. Search the FILES section using the term "600" and you'll find a smorgasbord of tech docs. For troubleshooting help, start a new topic in the Appliance Repair Tech Forum.
Total Appliance and Air Cond Repair Posted July 23, 2020 Posted July 23, 2020 SubZero Refrigerator Freezer 600 Series (Starts With Serial #1810000) Error Code: EE Service (Flashing) 38 Cause: SubZero Freezer compartment thermistor fault Error Code: 00 Service (Flashing) EE Cause: SubZero Refrigerator compartment thermistor fault Sub-Zero 600 Series and 700 Series Sub-Zero Error code: EC21 EC24 Cause of error code: Defrost Functionality Issue Solution 1: If temperatures are high call for service. Solution 2: If temperatures are near normal range: a – Clean the condenser b – Press and hold the door ajar alarm key for 15 seconds to clear the error code c – If EC Service light appears, or temperatures rise contact service for repair Sub Zero Refrigerator 400-2 and 427r-2 Error Code: EE Service (Flashing) Cause: Refrigerator compartment thermistor fault Error Code: 38 Service (Flashing) Cause: Several excessive compressor run times or Sub Zero Refrigerator evaporator thermistor fault Error Code: 38 Service (Steady, not Flashing) Cause: Several excessive compressor run times or Sub Zero Refrigerator evaporator thermistor fault Solution: To clear errors, first fix or repair component then turn unit OFF and back ON To clear the error code press bell ON/OFF key for 15 seconds To CLEAR the error code and reset your refrigerator: Press and hold the door ajar alarm key for 15 seconds to clear the code 1
