@ggg Man you still messing with this thing. Go back please and double ck your model number.
I'll have a look for you when I get back later this evening.
LOL, Thanks Quick. Bear with me as I'm not an appliance repair person. :)
The verified model number is:
FGF367CGSC
Cheers!
@ggg Remove the back top rear control cover. Looking at the control from the back you should see 5 spade terminals with 5 wires attached across the bottom. Counting from left to right unplug the 4th wire. E4
Tape the end of the wire so it won't touch metal somewhere and create a short. Do this when it's unlocked and unplugged!
Remember your board is haunted. So no telling what it may do next.
Hey Quick,
You're a genius! It worked!
Since it was stuck in the cycle and never "unlocking," disconnecting E4 stopped the motor but kept the oven in "locked" mode. This meant oven functions (bake/broil) would not work.
However your key phrase " Do this when it's unlocked and unplugged!" led me to wait for that fraction of a second, at the end of the cycle, when the door was ever so briefly "unlocked"... at this time I promptly released the door switch and had it in "unlock" mode. I then disconnected E4 and everything works as expected. We have no self-clearing function but never used it anyhow as we clean by hand infrequently so no biggie.
So thanks for the exorcism on our oven... we're happy, baking, broiling and ovening lol.
Much gratitude to you Quick and everyone who chipped in to help.
G
Good deal. You're welcome.
It's still haunted. I couldn't sleep in a house with a range like that.
All the best to you.
  • 2 weeks later...
Oh dear! I jumped the gun, the problem still persists. Ghosts are playing with me.
If you feel confident that the board is at fault, I'd be willing to give replacing it a try.
Do you happen to know if this part would be compatible?
Cheers!
https://www.kijiji.ca/v-view-details.html?adId=1374651270&requestSource=b
@ggg Seriously? If that's the case you have a bad door switch. Good heavens. Your door switch is haunted.
You don't think it could be the board?
This evening, we turned on the "Bake"... it ignited, started to bake... then after a few minutes, with no one near the stove, some clicking sound came from the "board" and the oven went off.
The timer continued to count down. Re-instated Bake mode, ... a few seconds... click click, off.
Chicken pot pie went into the microwave.
Board that I linked to in previous reply or... shop for new/used oven?
PS? door switch doesn't seem to be "loose" at all nor does it seem "touchy". It needs to be depressed significantly to engage, as it should....
More info in case this helps with the diagnosis.
@ggg
Now hang on? I thought you meant the lock motor was running?
Sorry for the confusion Quick... no no lock motor. This one has been quiet since disconnecting wire number 4
@ggg  Well GG I would sure be speculating the board is at fault for not allowing your oven to come on. Odds are that's your problem.
But without a little trouble shooting no way to know for positive.
Do you have or know how to use a volt ohm meter?
Thanks Quick... Yes I do have a voltmeter and know fairly well how to use it.
However can I first have your opinion on the board I mentioned? These used boards are rarely on sale at a reasonable price and if this particular one isn't compatible, I'll go with the final plan of looking for a used stove.
I looked at it. Say's in the disclosure it's off a Whirlpool. I would not use that.
Go to the back of the board. Set volt meter to measure volts AC. Attach one probe on E5 and the other probe on E2 and turn on the oven. You should read 120 or so. If you don't you know you have a bad board.
Thanks for your input and clear directions Quick. In that case I won't bother testing the board as such a typical board around the price of a used stove.
Final conclusion: We'll look for a replacement stove.
Thanks again for all your support. :)
Case closed.
