Manufacturer: Lg
Type of Appliance: Dryer
Model Number: DLE2701V
Hello all,  customer has an LG dryer That the display is clear dead.
The drum light does come on, but dryer will not start. Again no display whatsoever. So I need a manual please and any advice is appreciated .
Kevin
 Did I strike out on this one?  is no manual available?
All I could find with the wild card is some diagnostic mode procedures but with the dead display, that's not going to help me. I kind of need a wiring schematic to check board inputs/outputs. Pretty please!
Sometimes, we have to hunt around for the manual. If you see a white star in a green circle next to your topic title, that means we're aware of it and we're working on it. We did find the manual for you-- it's different from the one you found but appears to be a newer version:
  • Thanks 1
 Thank you so much Samurai, I really appreciate it! The white star/ green circle is going to really be a blessing to me! I guess if I had spent more time on the tutorials I would have learned that by now. I never want to come across as impatient, because I really am thankful for what you guys do. But it's tough not knowing whether or not ones query has been seen. So I really appreciate you giving me this little morsel of information! Apparently I have a bad control board that is no longer available. But I'm going to see about sending the board off for repair. This job is covered by AIG home warranty who has been good about paying flat rate. And I have had good success a couple times sending boards to the repair Shack in Lenexa Kansas.
