GE Profile: radiant surface element cycling problem
GE Profile Electric Dual Oven Convection Range - Model#PCB975ST1SS
Although the elements on-off cycling is normal, since few days ago, the front-right (3 zones) surface element turns on briefly (at any settings, including HIGH), with or without anything on cooktop, then turns off after 5 sec. It turns on again, but ONLY after 1 min, unlike it worked before when it had a more frequent cycling. I can hear several clicks during this 1 min cycle.
Any ideas what could cause this problem and how can be fixed? Thanks a lot.
All three sections doing it ?
Part number: WB24T10162
This would be what i’m Suspicious of , but it can be the sensor on the eye .
Yes, all three zones/rings are doing the same. What's is that sensor - is the limiter rod attached to the element ? Thanks
it's a top glass stove ...the burner coil is not at surface
Yes, if that part is bad you would have to replace the whole eye.  You may want to call a tech out on this one . Can be tricky determining which of the two parts are bad
With other words the issue seems to be the wrong timing cycle (ON/OFF), so this is the dilemma:  either the sensor is shutting down the element too early (after 5 sec) OR the infinite control switch turns on (back) the power too late (after 80 sec.)? Not sure if this can narrow the real problem: when top-glass is cold, the very first ON cycle - when you see the red coil - is longer (about 20 sec). Then all subsequent ON cycles are only 5 sec. Thanks a lot !!!!!
The only way to know for sure is to take a power reading at the eye , if the eye is shutting off and power is there the eye sensor is bad , if the power is going away it is the switch.  You have to be very careful doing live test
  • Like 2
I understand. I also found something interesting that might be useful on troubleshooting.
It is about the infinite switch "clicks" - which are normal. But also there are some "clicks" coming from the element area itself. They sound like the ones from switch, but more loader.
I was testing a working element: you can hear only the control switch clicks, for every ON or OFF of the cycle. There are no clicks from the element during the ON/OFF cycle.
However, for the main element, you can hear clicks from the control switch (but they not even, some of them are loader - when coils heats up at, and few others in between quieter - during the time when element is OFF, but the switch keeps trying to do something. It's really interesting the fact that the element turns back on (after that 1 min I told you about) ONLY after I hear a click from the element itself - it's like a relay there sending an OK command to the element (or switch) to turn on.
Any thoughts ? Thanks!
Sounds to me like you need to replace that element, (the hi-limit sensor and element HOT light is usually the control sensor on the element that most of the time now are not available separate - have to replace complete element, haven't looked up parts so don't know).
From your description I would say the hi-limit sensor is shutting the element down - you really shouldn't run these elements without a pan/load on them.
  • Like 2
sounds like its the element as Budget has mentioned. But if you read what evaapliance had told you about how to check that . That would be the route to go to definately make sure which part it is.  Have both on hand and do the electrical check as mentioned by evaapliance if you have experience with live checking components.  Then just return the part you didnt use..  Good luck and report back what fixed your problem ?
Thanks Darren, and everyone ! Could you please confirm this element part # WB30T10126?
yes thats the front right burner element Part #  WB30T10126         Ebay has one for $86.00  OEM    takes 7 to 10 days to get but usually Ebay is good for 5 days but I would expect 7-10 days on the safe side.       ERP has one also for that price but I am not sure I would go that route. that element gets a lot of use and I would stay with an OEM Manufactured one.
  • 2 weeks later...
Hi guys. Today I replaced the main radiant element (ordered from Amazon). The thermal limiter was indeed defective (the tip of the rod looked burned-out). Over the last days that element's warming light was on continuously. THANKS AGAIN EVERYONE FOR YOUR HELP !!!!!!!!
Glad to help, thank you for following up !
