How would a highly skilled Samurai repair person remove these Maytag (Model #MFT2976AEM00) (also Whirlpool Gold Series) bottom freezer upper bin stops from the slide bracket without breaking?
Over 6,500 people have watched the video below, many of them said they did a lot of searching for an answer without success. Appreciated this person's attempt to post a previous non-existing video, but even they were not quite sure how to remove the bottom freezer upper bin stops correctly.
It seems a lot of people would appreciate this information. Those bin stops are between $25 and $35 if you break one, not to mention the slide bracket assembly. Being able to remove the upper bin gives you access for repairs.
Thanks for your consideration and help,
This freezer bin stop removal video is for a Whirlpool Gold Series refrigerator.  My Maytag refrigerator is the same design.
Video link:
  • Replies 1
  • 16345Ed
  • MAGNUM
Insert a stiff blade putty knife behind the rail past the basket stop and force the rail inward while inserting a small blade screwdriver into the square slot in the rail. Pry out the freezer basket stop. Only one stop needs to be removed.
