Kenmore Elite Dishwasher model 665.13923K015
This dishwasher will start up, go to drain, go on and off in the drain cycle, all lights will go off. It will come back on by itself in normal wash fill up start to wash will then start draining. All lights go off dishwasher will stop and you can’t get the interface to light up nor the cancel button on it Shut power off to unit to no avail when I tried to put into cycle. There is correct power at junction box in DW. Took the front panel off and the control board fell into my hands and it looks like the tabs are partially broken so you have to gingerly put it back and when you put the panel back on you have to be careful that it’s in the right place( not the first time I’ve seen this on this model. Saw no broken wires. Its like there is no power going to the interface board and then there is. There is power to the control board. My thoughts are that it’s the control board. What are your thoughts. Thanks.
  • Replies 1
  • bowhunter
Anyone out there familiar with this problem?
