Manufacturer: GE
Type of Appliance: Dryer
Model Number: gfdn160ejww
Need this manual. I can't figure out how to take these new GE dryers apart.
Should be like these...
Thanks but it's not, I have that one.
@coolhandluke
Does mini manual have disassembly info?
its mini manual no: 31-16895
2 minutes ago, 16345Ed said:
@coolhandluke
I don't see that file number.
It was listed on searspartsdirect.com in parts diagram?  That’s where I grabbed it from anyway.
Does it show how to remove the top? If so can you give me a link?
Thanks.
Edited by deezus
Are you sure that wasn’t right Manual??
This is not that unit. This one has no screws on top its newer. I'm familiar with that one you posted.
Here mini manual number
Edited by 16345Ed
I don't think that's gonna help. I need service manual or someone to tell me how to take unit apart.
I can't say for sure, but I've run into a couple of front-load GE's (washers, but might be similar) that had me stumped for disassembly for a while. No screws on the back of the top panel. There's a hidden screw (on these, anyway) behind the cycle knob, and a couple others in the dispenser tray (again, these were washers, not sure for dryers). Once all the screws were out, I think the console lifted straight up off clips, then the top panel screws were along the front edge behind the console.
I can't find any other minii-manuals for that model that give any help on disassembly. :(
Edited by Rhubarb Tau
removed extra text
Yea it sucks because I've had to turn down 2 jobs now because of this....
Yep I done a few of those kind too... forgot about them.
7 hours ago, 16345Ed said:
Is that it?
59 minutes ago, deezus said:
Is that it?
Yep as I recall pull off knob, remove that screw and then carefully pry console off from top.
