Was told by repairman my Peerless Premier gas range 24" made under the Galaxy name - needs a gas safety valve for the oven.  Makes sense, after lighting pilot, would take hours before I could get the oven to fire up, then eventually the oven quit firing up days even days after the pilot was lit.  Was told TOAC could rebuild my old valve, but I found the correct valve is supposed to be 1285, Dey Distributing said Premier confirmed this - I read this replaced the 1282 valve - is this in fact the right gas safety valve for this range?  I really prefer to keep my old range from the 80's, I love a standing pilot stove over the battery ignition systems of today - or the electronic -
  • Replies 1
  • appleimac
  • darren412
call premier yourself and have the model and serial number ready.  Premier has a contact # and website.        www.premierrange.com    or    the # to call is 800-858-5844 .   The model # should be located below the top of the stove . Remove the grates  etc.  and lift up on the top lid  to remove it.  Its not that difficult.  Underneath the top lid on the stove cavity top , there should be a metal tag or sticker that is viewable with the model and serial # for your stove.  Right those numbers down before you call them because you will need that .   The model # you have shown might be missing some numbers.  I dont think that is the correct model # .  Assuming that it is definately the gas valve that is the problem ??   they will be able to direct you to the correct replacement gas valve.  Good luck
Edited by darren412
typo
