plott hound
so I need to do a little work to my ge model# PVXR333GT8WW.it has a couple of issues but nothing to serious.my question is how in the heck does a guy get his arms into the cabinet to re-route the belt?
I tried getting the old belt out and ended up donating some blood and skin.ended up just cutting it off because it was so worn out.
        thank
Go to YouTube and see if you can find the video that fits your needs.
first thing you need to do is resend the correct model #.    I do not believe you sent the correct model #  and serial #
It is a Canadian Model and a good model number and a basic USA model and uses this belt.Video also! Here Part number: WE12M29
GE Cabinets are made of razors. I always wear Kevlar sleeves when servicing.
Sometimes its it’s safer to call a professional.
plott hound
thanks guys,i got the new belt,front and rear bearings and the idler pulley replaced.was actually pretty easy after watching the video.laid on the floor with my trusty flash light and had it all back together in an hour.
        cheers and thanks again.
