HOW TO PUT KENMORE MODEL 253.70312211 REFRIGERATOR IN DIAGNOSTIC MODE
I recently changed defrost thermostat on it and the problem still is there.compressor keeps running with evaporator fan not.
  • Rasp933
  • 16345Ed
You wanna check for 12VDC at fan connector. If it’s got power and not running then replace fan motor. If no power it’s bad board or less likely a bad wiring harness. Can test at board to verify.
Thanks for responding.
I tried checking for current at the fan harness ended up shorting out the main control board.
Today I got new board and new fan delievered.paid just under $160 for both items.
