Bryant A\C
jkcal
I have a Bryant Evolution model 598 B that quit running.  On the circuit board
comm lights were flashing 6 times indicating a compressor VC\VH trip.  What does that mean? Is there a reset?
  • Replies 11
You had a low voltage signal to your condenser unit with no high voltage present, or the compressor didn't start.  Shut the power to the air handler to reset it.  make sure you have high voltage to the condenser before you turn the air handler back on.  That's a pretty sophisticated unit.  Anymore than resetting it once in a while or cleaning the drain you might want to let a pro handle.
Do you have a variable speed airhandler?  If its' only a year or two old you might look into an extended warranty.  They can be expensive systems to fix and they do break.
I don't have an air handler.  I disconnected the low voltage power and the unit reset, it seemed to run fine today.  Just don't know what caused the problem.
It shut down again last night.  There is high voltage present.
I also have a Bryant.  My breaker keeps tripping.  I've replaced the breaker and cleaned the contacts in the outside unit, but it keeps tripping.  Any suggestions?  Thanks..
Start you own topic john.
jkcal, This fancy unit of yours....  Did it come with your new home or did you buy it?.  If you don't have an air handler does this mean it's a package unit? Your problem could be with any one of your relays,  Your capacitors, even your crank case heater.  You might just want to call the guy and make sure he's a good one.
It was installed during a remodel, it sounded like a great unit. I'm not sure what you mean by a "package unit".  Hopefully the guy will be out again tomorrow and figure it out.
Guest ahammer48
Hello
Package unit= unit is one piece of equipment  either on the ground or on the roof.
Split System= 2 pieces of equipment. 1 piece, condenser section(compressor and fan) sits outside. The other piece, furnace w/ evaporator coil is inside, usually in the attic, garage or basement.
R U experincing brown outs or loss of electricity in Ur area?
It's a split system.  No Brown-outs or electrical problems at all.  It's shutting down when it turns to low speed output.
Guest ahammer48
Hello
Ok. I went to Bryants home page-http://www.bryantlincoln.com. Unfortunately Bryant thinks a sales brochure substitutes for service manual. Sorry:(. I think Jedi was correct about what that (6) flash code meant (vc/vh). It sounds like the compressor was told to start, but didn't so the unit went into lock out. It could B that when it goes into lock out the fan changes to low speed. Thats just a symptom, not the cause.
Is it always the same flash code or does it change? I think UR gonna have to call in someone.
The new furnaces with their electronic boards aren't easy to troubleshoot this way. If Ur not satisfied with the service you've been getting, goto the page above and Bryant will get U in touch with an authorized rep.
Hope this helps
jkcal,  are you having some kind of ongoing problem with this unit.  What's the whole story.  How many times has your guy looked at it?  Are these a pictures the same as your unit?  I'm sure your guy checked the relays and the caps.. right?  Unless you have an understanding of electricity and air conditioning you better let a factory pro fix it.  Do as ahammer48 suggest. You don't want to void any warranties either.
174623183_0f38346b78.jpg?v=0
That's the unit.  My guy came back and changed a relay (white) and the large capacitor on the left and so far so good.  I've noticed on start-up now a very "soft start-up" for the compressor, as compared to before the problem started, a very loud "click" before start-up.
