Manufacturer: Kenmore
Model Number: 106.51133210
Need tech sheet please :)
1 hour ago, NathanC said:
The tech sheet is in the downloads already -- you've just got to search with the Kenmore prefix removed and replaced with an asterisk, as shown in this video:
Posted (edited)
YES WELL AWARE OF THIS AND THE ONE THAT COME UP DOES NOT HAVE THE CORRECT WIRING DIAGRAM.
Edited by NathanC
Well, that's the only one that Whirlpool has for your exact model number. You can try this one -- it applies to a very similar model number.
Yes this is close but no cigar, I have a tech in San Antonio that has this fridge and the ice maker isn’t working. The optic board had a few wires in the connector that had pulled out. (No idea how) the diagrams I have, have not shown the correct diagram for the emitter and receiver board. In fact they haven’t show it all. Just a bucket switch which isn’t correct. This one has the optics in door with the ice maker up top in the door as well.
SearsPartsDirect.com lists W10516607 as the correct Tech Sheet
@NathanC -- the file that Brother Rhubarb Tau just linked to is the same one I told you to search the site for in my original post. It looks like it does have both an emitter and a receiver board in the schematic. Does the wiring it shows not match up with what you're seeing on the actual appliance?
Jesus!! Not only am I stupid and can't not read, but apparently blind. My bad this is what you get for looking over things to quickly. I did not see the remove Kenmore prefix. I've been using this site for three years. I guess every now and then we just forget. Got fixed with new harness, but need diagram to repair the wires to test to ensure correct diag.
A little late, but this should help.
