So I have one of these junky Samsung fridges with the bi-weekly freeze over of the evaporator coil.
I have seen there is a FD mode available (pressing top left and middle right buttons) but I can't get my fridge to go there.  I can't even get it to enter the demo (pressing left top and middle buttons) mode.  Is my touch pad trash too or do I have the wrong button combinations?
At this point I'm better off with a giant Coleman cooler and daily bags of ice than using this thing.
For RF28HDEDTSR/AA , the FD mode should still be top left and middle right. It's pretty unusual to have a bad touchpad, but they're typically pretty finicky about timing. You have to pres the two buttons at the exact same time (there shouldn't be any beep if pressed simultaneously), and hold them for about 20 seconds (a LONG time). Entry also won't work if you've pressed any buttons in the last 45-sec. to 1 min.
Finally.  I guess I was trying too soon after touching other buttons,  among  other failed attempts.
I'm also seeing what looks like an rD mode.  Is this a refrigerator only defrost mode?
Oh, and does it ding like that until you take it out of the mode?  Will it exit the mode on its own?
Yep, rD should run a forced defrost on the Ref. only.
Yep, it'll ding constantly while in forced defrost. It will time out on its own, after 30-45 minutes
If your Ref. evaporator is frosting up constantly , forced defrost may buy you some time, but won't solve the underlying problem. Either call a professional , or carefully remove the evaporator cover after thoroughly defrosting, check and/or replace the Defrost Sensor (the one clipped to the evaporator tubing with a plastic clip), and check whether the defrost drain is frozen or plugged
