Manufacturer: whirlpool
Type of Appliance: refrigerator
Model Number: 106.74209402
 hi , I looked up tech sheet  # 2225623  by model and searched but no luck -  please see if you can locate it - thank you
Edited by appltech500
added info
The Kenmore model number makes it hard for me to find the exact info for your model, but this tech sheet is very close -- see if it works:
And here we go, found the exact publication number you were looking for:
this is  the icemaker  .  maybe I posted wrong tech sheet #?  I got that from their commercial site using model # .  they also listed " service manual "  as  2314272.   model # 106.74209402  - this call is coming  in  about 10 days - I know its fairly basic unit  but when I was looking up parts I see It uses  thermistors and wanted to get  a tech sheet  showing resistance vs temp.
parts list  showed p#s  2218819 and 22188820   - I figured tech sheet would be best .   - thank  you
Service Matters doesn't provide a tech sheet with the pub number 2314272, but I found one with only a 1 digit difference in the publication number. I posted the link to that one in my first reply -- the one before the ice maker tech sheet.
 thank you for looking  , I did look at that  first  wiring sheet you posted  . I did not see any thermistors in diagram  though  ( according to parts look up 2188819 and 2188820 )  and  seeing that  frig had those that's what started me to look for a tech sheet so I could  test the values if need be .
Try this tech sheet then -- it's still not the exact one for your model, but it has a dispenser and thermistors like yours, and it gives a spec for the thermistor.
ok thank  you
