hi, I have a GE GSC23KSTA side by side fridge. The freezer fan which is behind the plastic wall at the top inside the freezer always starts up hitting frost. Can I cut out a section of that plastic wall to give more room to the fan?
lol, no!!!
Frost shouldn’t be building up. You either have a frozen defrost drain, a defrost failure or warm air intrusion.
You need to fix the frost problem not modify the machine.
Edited by 16345Ed
