Als repair
I am working on a G.E. CFE29TSDBSS.
Refrigeration works fine. Bottom freezes great.  It is maintaing 63 degrees in top box, set temp is 37. I unpluged it for 48 hours. Did 00 48  test and last two numbers keep changing. Did 00 47 and keep getting (0). Any  advice available? Am I even doing the right test. If my problem is a fan, where is the fan. The fan in back of the bottom drawer works fine. Could this be a damper problem?  Thanks for any advice.
Als repair
Title should read as follows. Fan (OR) Board?
According to the diagram on Sears, there is an Evaporator motor in the cooling tower in the refrigerator at the bottom right above the evaporator. Typically accessing this requires removal of all the shelves and then the evaporator cover. This will give you access to the evaporator fan for testing. I don't know if this unit's fan operates on the door switch, so make sure to cheat the door switch when checking for fan operation if you don't activate it through diagnostics. Accessing the evaporator will also allow you to examine the frost pattern on the evaporator or see if the evaporator is a block of ice. If the fan isn't running or the defrost isn't working and air cannot be drawn over the evaporator the the compartment will get warm even if the compressor is running properly. https://www.searspartsdirect.com/model/3cvocsuamw-000432/ge-cfe29tsdbss-bottom-mount-refrigerators-parts
Edited by MrApplianceMatt
Als repair
Hello Mr. Appliance Matt
 Thankyou so much. The fan was simply rusted and after manually spinning it and adding CRC, its working fine and quiet. Looking in the sears site. It is listed as no longer available. This unit is only 4 years old so I called my distributor and ordered a new one for possible future use. My normal job is commercial refrigeration, thanks again for your generous helpful input. Alan
Yeah I come up with that fan was replaced with this part number.Part number: WR60X26866
  • Thanks 1
Be careful I had one last week fan wasn’t running. It was getting power. I replace fan get call back, same deal warm in FF section.
Pull evaporator cover and see partial frost pattern.
I will always check temp of condenser in the future on these even if fan seems to have failed.
You guys are aware of the problem G.E. had with this issue right? The service bulletin called for not only replacing the fan but also updating the software via a sum board.
Nope bulletin updated
Repair: Replace the fresh food evaporator fan with part WR60X29099. The new fan is a direct replacement for the original and does not require software to be updated (updating the software with NewFI or with a SUM is no longer required for this repair). When the original fan part number is ordered it will supersede to the new part number (WR60X29099).
