Am working on this range and the upper oven is not heating up to temperature, also the oven light will stay on and not shut off making it quite warm in the oven and since the light is a halogen it get blistering hot. When you touch the display to turn it off it fades but comes right back on. There was a power outage in this town a few weeks out and after checking the components I’m not getting the correct current to the upper oven. I am going to change the control board but the controllers in the parts breakdown doesn’t state which controller is the one for the upper oven ( number 15 and 16 in the parts diagram but doesn’t seem to distinguish them). Any clues? I am getting old and maybe it says it but I was blind at the time😁
  • Replies 4
  • bowhunter
  • Fixitrightthefirsttime
  • MrApplianceMatt
  • 1 year later...
Hi. I’m running into the same issue. Have not been down to the oven yet and I would like to know which one is upper and which one is lower. I did go to that Tribles link that MrApplianceMatt provided and it does say that WB27X25552 is the upper. Just wondering - was anyone else was able to verify that? Is it for the upper oven? And is WB27X25553 for the lower oven? Thank you
If that is the only other controller than it proves to say that WB27X25553 is the lower board. Wasn’t able to verify.
Thank you for your quick response bowhunter! GE parts rep also confirmed that you were right.
