Manufacturer: Kenmore
Type of Appliance: refrigerator
Model Number: 106.51782412
Ice maker - newer style in door - not working. Used tech sheet that was with unit, did IM tests and it failed.  Showed IM thermister to be open and it would not acknowledge that IM tray was back to home position even though it was (and I couldn't get it to fill).  Replaced ice maker and it is still not working with exact same symptoms.
Would like a manual on this model so we can research deeper before going back out.
Also, if anyone has much experience with these and has any ideas please share your thoughts! Thanks.
Not finding anything on this manual, unfortunately. Common problem with Kenmore models -- the actual manufacturers don't bother to provide information on them.
I think he working with this Sankyo ice maker. This may help.Also look for broken wires down by the lower freezer door hinge. Tech sheet  Service and Wiring Sheet - W10670787 - Rev C.
Thanks!  I'll check these out.
  • 5 years later...
Were you able to find the solution?
