Bintiwangu
Manufacturer: Samsung
Type of Appliance: dishwasher
Model Number: DW80J3020UB
i found a manual here with the US suffix instead of UB. I downloaded it, but it doesn't show any other numbers that it corresponds to.
I hate to waste your time, but I still don't understand how to tell if, "pretty close" is close enough unless the manual lists out the other numbers it applies to.
This machine will hum but not fill. Which makes me suspect the fill valve. Thank you!
The UB and US models call for the same water inlet valve if that's your LOI
Bintiwangu
Thank you,
I looked at the sheet, and it shows line in from CN202 #1Red to the valve, and other wire from the valve to CN202 #3Yellow Neutral.
If it's humming, I figure the valve is bad. But trying to get a plan before I go look.
This one says that it applies to your model:
  • Thanks 1
