Bintiwangu Posted May 31, 2019 Posted May 31, 2019 Manufacturer: Samsung Type of Appliance: dishwasher Model Number: DW80J3020UB Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes i found a manual here with the US suffix instead of UB. I downloaded it, but it doesn't show any other numbers that it corresponds to. I hate to waste your time, but I still don't understand how to tell if, "pretty close" is close enough unless the manual lists out the other numbers it applies to. This machine will hum but not fill. Which makes me suspect the fill valve. Thank you!
MrApplianceMatt Posted May 31, 2019 Posted May 31, 2019 The UB and US models call for the same water inlet valve if that's your LOI
Bintiwangu Posted May 31, 2019 Author Posted May 31, 2019 25 minutes ago, MrApplianceMatt said: The UB and US models call for the same water inlet valve if that's your LOI Thank you, I looked at the sheet, and it shows line in from CN202 #1Red to the valve, and other wire from the valve to CN202 #3Yellow Neutral. If it's humming, I figure the valve is bad. But trying to get a plan before I go look. 1
Team Samurai Son of Samurai Posted May 31, 2019 Team Samurai Posted May 31, 2019 This one says that it applies to your model: 1 1
