GE CFE29tsdfss Water dispenser and ice maker not working
If i enter to the service menu (3 buttons pressed for 3 sec) and do a 0016 test (exit and reset all components) the water disppenser works for a few minutes even the flow meter works. Then it just stops working.
Can't find the service manual for this one, its on this website posted by Chat_in_FL but i have no access to it.
  • MrApplianceMatt
  • elshell
Posted Images
I have a picture of the error codes i received after clearing the codes (00 01) then restarting (00 16) then working water dispenser for a couple of minutes until it just stops working.
in the picture the error codes
https://ibb.co/KhtW2PQ
According to GE, the codes 801-805 are not applicable to any model (whatever that means). 304 is an error code for freezer exceeding 72.5 degrees Fahrenheit. 4 is the error code for the freezer evaporator thermistor. I would look into replacing the freezer thermistors, and probably all thermistors since they're pretty inexpensive. IDK how these would affect the dispenser. It's possible that the 801 code has something to do with it, but GE is not very forthcoming with what that means, even in their own service manual. All the main board failure codes are 400 numbers.
Edited by MrApplianceMatt
