Oven door seal
megadan66
I've found the door seal for this,with no help from the model #.It's the old mesh wire covered with some sort of woven fabric.All I need to know is if you have to take the door apart to install it.......Thanx.............Megadan
  • Replies 1
Yep, take door off the hinges, lay on a protective pad and then remove the obvious screws to disassemble and replace the gasket. Just keep track of how everything goes back together, may want to take pictures as you go. They're all pretty similar, this post at my blog has some photos that will give you an idea of what to expect: http://fixitnow.com/wp/2006/06/09/removing-the-door-gasket-on-a-dacor-range/
