Greetings all!
A couple days ago I received the LE code on my WM3170CW washing machine a few minutes into running a cycle. The drum spins easily in both directions when the power is off. When attempting to run a wash cycle, the motor will try to move but magnetically locks and hums. Occasionally it will spin briefly for about 1/2 of a rotation and make a loud growling sound. Searching the code, it seemed the most likely cause was the hall sensor. I bought a replacement hall sensor (6501KW2002A) from the local appliance parts store and installed it. However, that did not resolve the issue. So, I tested the continuity with a multimeter from the motor and hall sensor connectors to the main board and every pin showed continuity. I physically traced the wires and didn't see any external signs of damage. I tested the resistance of the stator and it showed 10-11 ohms between all three pins. The rotor has all magnets and shows no sign of wear. Considering all this, I bought a used main board. After installing the new board, the issue continued. Any ideas? Replace wire harness? Stator? Rotor? Thanks in advance and any and all assistance!
  • Replies 5
  • tburk19
  • MarcP
  • john63
  • evaappliance
Motor Wire Harness.
EAD62061005
Edited by john63
John63,
I have now replaced the wire-harness and the stator. Problem persist. The only two pieces that I haven't replaced are the rotor and the the wires from the harness to the main board. Ideas?
  • 1 year later...
I am having the same problem.  I have replaced the hall sensor, same problem.
What should I replace next?
How long should I expect a response to take?
you may need to start a new topic with your make and model to get everyone's attention
