I have an LG Direct drive dishwasher getting LE code. It does pump the water out then it files but after it files then it gives the LE code. But never runs the washing part. if I turn it off and back on and select a cycle it will pump the water out. so what is wrung with the dishwasher. gest for info we did have a power loss three times one right after another and the dishwasher was running at the time.
  • Replies 1
  • mraswm
  • bkandesr
Hard to say exactly without some testing. Sounds like the main control got some electrical damage. You would need to test power going to the motor when the motor should be running. If it is getting power, you would want to check the coils on the motor. If not power, you probably need a new control board.
