material between wall and gas oven/range -
Pulled out Galaxy - made by Premier - standing pilot range to fix gas safety valve - this unit is slid in between two cabinets - I noticed on the back wall when cleaning it a bit of brownish on the wall, as if the material may have been charred just a bit over the years - was wondering if I should install something on the wall behind the oven to protect the wall more from heat and stuff?  These condo's were built as cheap apartments in 68, and turned into condo's in 1980 when these stoves were apparently all installed -
  • Replies 1
  • appleimac
  • evaappliance
I wouldn’t think you would have to, but if you want to go the extra mile it can’t hurt to do it either
