Manufacturer: GE
Model Number: GSH22SGPBSS
Many GE refrigerators in search but not this one. I need to replace the main control board
and this model is called an ENCODER with the serial number prefix LF2. The instructions
call for the thermistor wire to be cut in pin 2 of the J1 connector. There are two white wires
on the 9 prong connector in the instructions positioned at J1 and J2, 2 separate pictures.
The actual connector on the fridge has wires in J2 through J8 only with two white wires
In the J2 and J3 pin positions. So I need the schematic to see which wire is actually the
thermistor wire that needs to be cut. ( Both diagrams in the instructions show the second
white wire being cut. Actually, one picture shows J1 and J2 a jumper with another white wire
coming into J1 pin position.)
  • GreenestOne
  • Son of Samurai
Thank you for the post, but the J 9 prong connector on the actual refrigerator has two white wires, one at pin 2 and one at pin 3. The connector in the diagrams that came with the board
installation instructions show a white wire at J1, and another white wire at J2. In the actual connector onsite there is NO metal pin at J1. So I'm wondering if things are shifted to the right
one pin. That is why I wanted to see a schematic, to see what the two white wires are actually supplying.
@Captain Dunsel uploaded some info for you -- check it out:
