My fridge/freezer is leaking within the bottom panel on the freezer side and is holding water within the bottom panel of the unit. I am getting water to drain into the drain pan on the right side. No blockage there. Maybe some water is going into the drain tube during the defrost cycle and some water is missing the drain hole and leaking into the interior cabinet/shell of the fridge itself?
Frigidaire model LER5636EQ1
thanks
  • babymaker
  • Captain Dunsel
  • Vance R
That's a Whirlpool dryer Model Number!
Sorry. FRS6LF7JS5 is model no
If the defrost drain is clear. Next place water would be from is the ice maker of ice maker fill tube.
