Kitchenaid stove Model KGFA906PBLOO
desertfox40
Konichiwa.  Kitchenaid stove reads "Stuck Key"  F2E0.  Need help in finding out what this code means and how to clear.  Domo arigato gosaimashita.:cool:
Gomenasai,  ModeL #KGFA906PLB00
  • Replies 4
Recheck the model number, not coming up anywhere for me...
Here are some listed fault codes, however do not know if they pertain to your unit.
F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC)
F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
F2 - E0 Shorted keypad Replace keypad
 Sort of need to see which is for your unit....
Arigato for the fast reply.  Model # is KGFA906PBL00 OR PBLOO.  Don't know if the last two are zero's or O's.  Thanks.
Model number does not come up, find the tech sheet located within your range, it will tell you what this means for your unit...
