 Whirlpool GW395LEGB Oven gives F3 error, sometimes.  Should I suspect the oven temperature sensor?  What should the ohms be on that sensor?
It does not do it all the time.
  • dj1100rt
  • 16345Ed
  • Bluebayou
Measure sensor value (between connector pins) 1000 Ω @ 32° F (0° C) and 2697 Ω @ 900° F (482° C) (approximately 1080 Ω @ room temperature). If measurement does not correlate to real temperature, disconnect power, replace sensor.
  • 2 weeks later...
...Well, I replaced the oven temperature sensor, even though, it may have been good.  Oven worked for a while (roasted a turkey) and today, I got the EO -F3-  error.  What do I do now?
I would carefully inspect the wiring from the temp sensor to the control board for nicks or cuts allowing the conductor to touch the frame of the oven.
Test the resistance of the temp sensor from the connector (the disconnected connector) at the control board.  That way you are verifying the wiring to the sensor at the same time.
Other than that, I would replace the control board.
