Having gas safety valve sent out to be repaired on a vintage 1980 Premier (Galaxy) 24" gas range - was noticing flexible grey gas connection line going to the black gas pipe in the wall - I was reading these should be replaced when disconnected - what is best to use now?  Read of problems with lightning strikes nearby exploding gas lines in some areas - most of what I have read says replace with yellow coated gas lines - but what about these new "safety" gas lines that are supposed to drop the level of escaping gas in case of a major gas leak somewhere? What is best to use -
  • Replies 0
  • appleimac
