Sears Kenmore Model 110.96283110 - constantly blowing max heat thermostat ever few loads.....
I know.. 20yrs I should be happy and buy a new one... but there are no different then this older Sears kenmore!  So the heating element was changed about 7 years ago.. all good til recently. Every 5-6 loads it will pop the hi temp fuse in the heating element area. I am noticing the element will not cycle nor change temp range when selecting Hi, Med, Lo. i finally blew the thermal fuse near the cycling thermostat so I replaced them both. The funny thing is.. I tested the cycling thermostat on a thermal stove top and a laser temp sensor and it works!!!  So did the new one that was installed. I tested them side by side and they both trigger on/off withing seconds apart.  Well anyways  the newer cycling thermostat is in and running today. I dont have my hopes up so I really could use some good guidance on what to look for as far as this thing constantly popping the heat off.  I am on a really tight budget and had a new motor around 7 yrs ago in this thing as well... please help.
Before you ask... new exhaust pipe & exit installed... inside all cleaned out as well.
Ron
  • Replies 7
  • rpriz
    4
  • vee8power
  • evaappliance
  • David C
oh its the Model 62831... sorry for typos lol
What's the part number of the replacement parts you used?
good question.. tried so many  generic brands with the same temp ratings.. not even sure whats in there now.  the seems to be a small screened area where the hot air leads into the drum along the back side of the unit according to the diagram. Does that ever get clogged? I am sure thats not the issue as the heat doesn't seem to be cycling.
Have you checked venting to the outside? Also, use factory parts, not aftermarket.
Normally no, but there is a area between the lint screen and blower that does occasionally.
"Normally no, but there is a area between the lint screen and blower that does occasionally.  "
the area.. shroud that holds the lint screen and funnels air thru the blower.. does collect a surface layer of lint but i constantly clean that as I am in there at least 1x every 2 weeks fixing the thermal cut off thermostat. I dont see any reason for it to be a bad air flow situation.. I have clean out everything and constantly checking.
Does your dryer have a air dry setting and if so do you have heat on that setting
