GE GSL25JFTFBS
My GE refrigerator becomes warm one day and works fine next day.
Replaced Start relay and Main PCB.
What did I miss?
Kyungmook Lim
Both sides, freezer and fridge get warm? And when you say warm, you mean 60-70°F? Is there any noise coming from the unit when it’s not working? Lights on inside?
Both sides get warm. There is power always. Yes, rise to room temperature
Opened up refrigerator to see what was wrong found some frost but not much only on the coil. But the fan sounds like a variable speed fan
Pull of the electronic control and look behind it at the solder joint on the main relay.  Also, look for swelled up capacitors. These boards fail.  WR55X10942
I think he said he replaced the board already. That does seem like a likely cause though
  • 1 year later...
I REPLACED TEMPERATURE SENSORS IN THE FREEZER. THAT FIXED IT. THANKS
The evaporator sensor, or freezer compartment sensor? The latter rarely ever fails
worx appliance service
thermistor
