Hi, The front door outer glass was broken on my Whirlpool double oven gas range.  Everything else is intact including inside glass.  I have looked on all the parts websites and even contacted Whirlpool direct.  They say it's discontinued with no replacement available.
I can't believe I'd have to buy a whole new range because of this. They cost over $1,000.
Does anyone have any suggestions?
  • Replies 5
  • Jenn8
  • Budget Appliance Repair
  • Vance R
Talk with a glass shop, they maybe able to cut one . Or try ebay to see if anyone has one for sale.
If you would like help you really need to help us by giving the full info.
You have only given a partial model number - there are 18 different models that start with GGG388LX
There are 3 more digits to the model number that is the color code and revision.
Also there are two ovens/doors which is it the top small or bottom large?
You could substitute a different color front if didn't mind the look - three different color versions, (Black, Stainless and White)
I did a quick search on three different models, lower large oven door front and found one is readily available but very expensive ($350-$425).
W10346113 Assembly, Door Glass, Black (plenty avail. $350-$425)
The last 3 digits are Q01.  It's the white one that was discontinued.  I considered the black glass but figured if I'm spending thar much, might as well invest in a new stove.  The white glass was a lot cheaper for some reason.
@Jenn8
Yea, I've been doing appliance repair for 34 years now and find the pricing absolutely crazy!!!!!
Same exact part in your case except for color and it's 3 times more
Order a Left side or Right side part like an oven door hinge, one is $15 the other $6, makes no sense what so ever!!!!
Normal listed retail for the Black glass is $392-$450 found a place where you can get it for $260 + Shipping, (only about $100-$130 more then the white if you could still get it).
https://www.automaticappliance.com/parts/whirlpool-outer-door-glass-blk-w10346113
