about a week ago there was no ice, i unplugged it, and ice was flowing again, however now, no ice again and it does not appear that water is flowing into the ice maker, the water on the door is flowing fine (although a little warmer than normal) - i read to change the filter ???
  • Replies 4
  • Vance R
  • DaveE
  • 16345Ed
There should be a tech sheet in the kickplate area. Put is into diag mode and do test 25 the dispenser and i/m fill test to confirm water flow. From your description it is a possible frozen fill tube to ice maker. If dispenser is working it probably has a non clogged water filter. The consumer help usually recommends changing filter because most people don't replacement them regularly.
but if there was an issue with the filter would the water in the door still work ?
Correct, if the filter was the problem both dispenser and ice maker would have issues.  The consumer help just goes through generic steps. Example - unplug unit and wait a minute and plug back in to reset main board. You should be pass that step, moving on to the diag mode to check water into the ice maker.
Possibly weeping valve clogging fill tube with ice. I’d get my eyes on that fill tube.
