KitchenAid Dishwasher KDTE704DSS0 doesn't dry
Hi!
I have a KitchenAid Dishwasher modelo KDTE704DSS0 and it doesn't dry. I tested the heater element and the resistance value is 13 ohms, then I tested the thermostat in cold and it has continuity. I need the instruction for to put the appliance in test mode, maybe it could help me to find the cause of the fail. If someone knows how to find the posible cause or has the service manual of it and share with me, so I can try to solve the trouble.
Thanks in advance!
  • Replies 1
  • MrApplianceMatt
  • Gustavo
Pull the kickplate off and look behind the insulation. Taped to the back of the kickplate is the tech sheet that will have the procedure and the error code explanation
