I have a LG gas dryer unit will power up but when the start button is pushed the drum does not turn. I do not hear any clicks on the board when the start button is pushed and the belt switch and the door switch are good
  • Replies 6
  • Danallan
    4
  • 16345Ed
  • Scottekarate
Always provide model number
how do you know belt switch is good?
Its hard to say without a model number. A quick thing to check would be to remove the top panel or otherwise raise the top and tug on the belt. It should be visible on the drum. If it's loose or not there, you have an idler issue or broken belt.
Tested it
Just now, Danallan said:
Tested it
I’m asking how you tested it...
Am I also to assume the belt is ok? you never mention it.
I tested it. Model number dlg2351r
With a meter yesbelt ok
