https://products.geappliances.com/appliance/gea-specs/JRP15WWWW
today my oven died. nothing works, not even the clock.
i had an aluminum engine inside, it touched the boiler element.
there must be a fuse?
my oven worked great just ten minutes before, i had a pizza under broil.
Reloadron said:
That was your last post. Did you resolve the shock issue? Did you install the dual 240 Volt breaker and assuming you did then has it been tripped?
Ron
never did anything ti fix the shock issue.
the breaker was tripped, i forgot to say. & i re-set it, but no luck.
  • Replies 6
  • juro
    5
  • David Jero
  • Up and running Appliance repair
Sounds like the thermostat shorted. It’s hard to get to. I believe it’s in between the over toward the back. U have to pull out the oven
the digital clock is dark, too.
