EW23BC7IS4 Electrolux French Door Refrigerator
Control panel flashing on and off. Water dispenses on it's own. Was able to stop water from intermittently dispensing by engaging control lock. How do I retrieve  error  codes. Thank you
  • FDrozd
  • MrApplianceMatt
  • Lennydoom
I had a Frigidaire that had a water leak behind the dispenser board causing very similar symptoms. Don't think you can retrieve error codes if the display is all wonky.
