this dryer has a bad control board part# dc92-00322E.
it is less than 10 years old and the part is no longer available.
Is there any place that the board can be sent to repair
Larry
@lthodo
https://circuitboardmedics.com/
If you look on the back side of the board, you may see a burnt out solder joint. Usually the solder joint at the heater relay. Solder that back up and you may fix it
