Manufacturer: Fisher & Paykel
Type of Appliance: Dryer
Model Number: DEGX2-96102-B
Dryer has a loud squeak.  Really, really loud high pitched squeak.  Like metal on metal.  I think it's the bearing but I've never seen one go bad. In fact I've only worked on a couple of these dryers, mostly for heating issues.  Has anyone ever changed a bearing  and if so, is it as bad as it looks in the service manual?  I'm wondering how much labor I should quote.
Thanks in advance!
Jeff
That's a really good video.  Thanks for your input.
Jeff
Did you use a 22 mm or 7/8 socket? I saw both were quoted.
Jeff
Pretty sure was the 22 mm
Jeff
Basically same size hence they are both quoted
It needs to be a thin wall socket , a tube spanned might be better if you have one
  • 2 weeks later...
Did the bearing today. It was actually pretty easy. I ground just a little off a 22mm socket and it fit just right. I now have a custom tool for future use 😁
Good job @jroedl
And thanks for the update!
