Manufacturer: GE
Type of Appliance: Bottom mount refrigerator
Model Number: DFE29JSDASS
Just realized I do not have this service manual and need it asap. The mini manual for DFE29JSDDSS is on here, but does not specify if it will work for DFE29JSDASS.
Need manual for DFE29JSDASS, please.
Thank you!
  • sethsc77
  • johnsavit
  • Captain Dunsel
Uses this mini manual.
Similar to this service manual.
Much appreciated!
  • 9 months later...
What did you find? I am on a no cool fresh food call and found the same symptoms. Led to condensor fan not running. Then it went into defrost before I could unplug the bad ff evap fan to see if it was pulling the 5v on the board down and killing the condensor fan. Thanks for your response!
