Samsung RF268ABRS/XAA-00
Edited by Thall
Based on your tag, I’m guessing you’re looking for the service manual. But again, this is the wrong forum for that. This is where you want to post your request:
https://appliantology.org/forum/16-appliance-service-manual-requests-forum/
But you gotta watch the YouTube video that explains how to search for manuals. This one and the last one you requested are all very easy to search for if you watch the video
  • Thanks 1
  • 2 weeks later...
jamesmartin248
Hello Friend,
Check for these possible issues.
There are several possible causes when a refrigerator doesn’t keep your milk cold or your ice cream frozen. Before you attempt more complex repairs, try these simple fixes if your refrigerator is not cooling and if your freezer is not working:
-Be sure the fridge is plugged in and getting power. The light should come on when you open the door.
-Check the thermostat to make sure it hasn’t been turned way down by mistake. If your fridge/freezer thermostat isn't working, get these easy to install thermostats on Amazon.
-Be sure the vents on the back of the freezer compartment aren’t blocked by boxes of ice cream or frozen vegetables—the vents have to be clear for cold air to circulate.
-Vacuum the coils under or behind the fridge. Clogged coils can cause poor cooling.
-Check to make sure nothing is stuck in the condenser fan and that it spins freely (models with coils on the back won’t have a fan). To do this, unplug the fridge and pull it out. Clean the fan blades and spin the fan by hand to see if it’s stuck. Plug in the fridge and make sure the fan runs when the compressor is running. If the fan doesn’t run, see the directions below, which show how to replace it.
If it doesn't help you might need to contact a refrigerator repair service.
Ă—
Ă—
